Gasket under rocker assembly
Old Apr 24, 2012 | 05:27 PM
KJS's Avatar
KJS
Default Gasket under rocker assembly
Newbie needs help... First, this is a great forum!
I need help trying to get my message across in getting the correct part, or where to go to get it.
I have a 1990 Civic LX 4 door sedan with over 150,000 miles and still runs like it was just driven out of the showroom.
I have a leak in the spark plug tubes. I purchased the Valve Cover, Grommet and Valve Tube seal kit. HOWEVER, I know that under the rocker assembly on the head there is also another set of gaskets/seals that should be replaced. But I cant seem to find anyone at a parts store that knows what I'm talking about. They keep trying to sell me (and the first one got me) the gaskets that go on the valve cover.
Where can i go to get the gaskets/seals that go under the rocker assembly?
Much appreciate any help you can give is appreciated!
Old Apr 24, 2012 | 06:55 PM
droopy128's Avatar
I'm at a lost too.. which gasket you talking about? is it a cam seal? valve stem seal??
Old Apr 24, 2012 | 07:40 PM
KJS's Avatar
KJS
Its not the valve stem seal. Its not the gasket that connects to the valve cover at the spark plug tubes. Its beneath the valve rocker assembly. Here's a video showing where they are....1990 Honda Civic Spark Plug Tube Seals
Old Apr 24, 2012 | 08:58 PM
droopy128's Avatar
ah.. those are the lower tube seal (o-ring), it usually comes with head gasket kit, but not the valve cover kit.
ask them for the lower tube seal, between cam assembly and head, it an o-ring type.
Old Apr 27, 2012 | 03:31 AM
KJS's Avatar
KJS
Thanks Droopy!
annette's honda
Jan 20, 2013 09:43 AM
powerplus
May 7, 2012 02:52 PM
tsmith944
May 6, 2011 06:22 PM
Street Sniper
Feb 21, 2007 02:02 PM
JLguy
Jan 20, 2007 01:14 PM
