rocker arm assembly stuck on head
Old Jan 13, 2013 | 06:53 PM
annette's honda's Avatar
Default rocker arm assembly stuck on head
1993 b7 head on my bench. has all 16 bolts loose. valve adjusters all loosened. spark plugs removed. this engine has never been taken apart. I would appreciate any suggestions to safely remove the rocker assemblies.
Old Jan 16, 2013 | 11:24 AM
zerojett's Avatar
If you've never taken one apart I suggest you get a shop manual for that car.
Old Jan 20, 2013 | 09:43 AM
Hey zerojett. Thanks for the advice. I do have the 1300 page manual. Maybe its not detaied enough. Engine oil 'varnish' had the cam caps glued down. A little soak in toluol freed it up nicely. Thanks again.
powerplus
May 7, 2012 02:52 PM
KJS
Apr 27, 2012 03:31 AM
tsmith944
May 6, 2011 06:22 PM
Street Sniper
Feb 21, 2007 02:02 PM
kman92civicsi
Jan 2, 2007 03:34 PM
