Getting Rims Off...
Old Jul 28, 2010 | 04:21 PM
skullcandy247's Avatar
Default Getting Rims Off...
I was hoping someone could help me figure out how to get tires off of a car thats already lifted up off the ground. The Lugnuts werent loosened before it was lifted and now when the lugnuts are spun the whole tire spins. Theres a local you pull you pay junkyard that puts all the cars up on stands and some lugnuts on some cars were loosened before being put up but most werent. You can pull the rims/tires and buy them but i couldnt get the ones i needed off as the tires just spun and spun and spun. Any help would be appreciated. Theres no way to bring the car back down to the ground off its stands so thats not an option
Old Jul 28, 2010 | 04:27 PM
N0safebetdx's Avatar
shawty
Have someone else hold the tire while you try & get the lugnuts off?
jprommel's Avatar
Angry Admin
hit the brakes? lol i've also found that like pull up then quick back down in a jerking motion and repeat until u break the lugnuts loose works.
Old Jul 28, 2010 | 05:27 PM
DaOne's Avatar
pull the e break.. and step on the break pedal?
o.O
Old Jul 28, 2010 | 06:09 PM
civicexracer's Avatar
Find someone with an electric impact gun? Get a crow bar and someone else to hold the wheel still? Hit the brakes? Drop the car enough to get enough weight on the tires? Not really rocket science.
Old Jul 29, 2010 | 04:22 AM
Sounds like you need to discuss the siutation with the owners of the pick n' pull. Seems to me putting the cars in the air with the lugs tight is probably a theft prevention technique
Old Jul 29, 2010 | 12:44 PM
I talked to them about it and all the lugnuts are supposed to be loosened before putting them out in the lot but I guess the workers dont feel like doing it sometimes.
I tried the ebrake and holding down the brakes but still spins, the brakes might have been disconnected before (i didnt check). I'll have to try everything else listed here in a day or 2 when i go back. Thanks
Old Jul 29, 2010 | 01:34 PM
jprommel's Avatar
Angry Admin
seriously try a quick jerking motion, it does wonders up and down up and down. i do it all the time cause my dumb *** always forgets to jack the car up b4 i break the lug nuts loose
Old Jul 29, 2010 | 02:21 PM
On the front wheels you could put a pipe wrench on the axle to hold it, assuming it is still there.
Old Jul 29, 2010 | 07:09 PM
definatly going to give it a try. had a friend tell me the same thing today
Derek2000
Aug 2, 2009 09:39 PM
txedomask433
12
Jul 15, 2007 01:57 PM
cornerblitz59
Jul 24, 2006 10:51 PM
custm93civic
Jul 24, 2006 12:10 PM
baker7598
Jun 1, 2004 06:54 PM
