The godly beast mobile won't start.
Old Dec 8, 2007 | 10:57 AM
timmytim's Avatar
Default The godly beast mobile won't start.
REFER TO: Engine Replacement Question, Transmission Linkage, Won't Start. --- Project failing!
My other threads are gettinglengthy going to post up a fresh one here.
Progress to date:
Comments: Engine install went rather smoothly, few snags but no major issues. Three day install and an arguement with the father, RAWR!
GO BABY GO, CAR FIRED AND DROVE 2 BLOCKS TODAY [12-9-07]
Current problem:
Car stalled in first gear from stop. Will not fire. ---- Assuming timing belt slipped a tooth due to a loose tensioner pulley bolt.
Diagnostics attempted:
None. Going to check dynamic timing again to make sure tooth didn't slip. Update soon!
REMEMBER:
Vehicle did not have problem starting before I swapped to the japanese long block. Motor turned over well and would not fire due to unknown reasons. That's another story.
SWAPPED:
INTAKE MANIFOLD
EXHAUST MANIFOLD
DISTRIBUTOR
FROM OLD MOTOR TO THE NEW MOTOR
PICTURES:
#1 [IMG] http://i166.photobucket.com/albums/u...ah/starter.jpg[/IMG]
[IMG] http://i166.photobucket.com/albums/u...mmah/fuses.jpg[/IMG]
[IMG] http://i166.photobucket.com/albums/u...mmah/click.jpg[/IMG]
[IMG] http://i166.photobucket.com/albums/u...mah/vaccum.jpg[/IMG]
[IMG] http://i166.photobucket.com/albums/u...mah/topend.jpg [/IMG]
The Beast Herself in all her primered glory! http://i166.photobucket.com/albums/u...ah/Misc010.jpg
Check my wiring/hoses please??? http://i166.photobucket.com/albums/u...ah/Misc007.jpg
Another shot of the mysterious connecter in it's home location (just behined the hood release). http://i166.photobucket.com/albums/u...ah/Misc009.jpg
Old Dec 8, 2007 | 11:20 AM
Default RE: The godly beast mobile won't start.
The starter circuit is pretty simple (see picture). Can you describe what you mean by "arched starter" in the context of the circuit diagram?
[IMG]local://upfiles/25538/397F3612C77248E690AE1D8CE30577A0.jpg[/IMG]
Old Dec 8, 2007 | 11:24 AM
timmytim's Avatar
Arched "hooked to Bat+" to "cant see other side" ... lol with a screw driver. REFERENCE : STARTER.JPG
Bascially spinning the starter motor there at the solenoid instead of with a key in the ignition.
Old Dec 8, 2007 | 11:33 AM
timmytim's Avatar
ORIGINAL: RonJ
Your clicking sounds are coming from the Dashpot Control and Purge Cut-Off Solenoid Valves. These components control air intake and evaporative emissions, so I don't think problems with either would affect power to the starter. Turning the key causes these components click, so maybe the ignition switch is okay?
That's what I was thinking. I'm DAMN FRUSTRATED RIGHT NOW. Does anyone else have any insight?? Ron, I'm going to try to find a home for that little white connector while the pizza dude gets here. I appreciate you letting me pick at your brain for a while. Thanks in advance! (notice my feeble attempt to not be so pessimistic with the thread title? lol)
Old Dec 8, 2007 | 01:02 PM
Based on information you have provided so far, you may have a problem with both the starter and the BLK/WHT wire circuit between the ignition and starter. The pictures tell you how to troubleshoot these problems. I hope it helps.
By the way, do you think the unknown male coolant connector may be part of the EACV or Fast Idle Valve?
[IMG]local://upfiles/25538/2B9A8723B9F149E1A53E34B9B56705FC.jpg[/IMG]
[IMG]local://upfiles/25538/C2449803085845F0818A377D19D271A4.jpg[/IMG]
Old Dec 9, 2007 | 02:12 AM
timmytim's Avatar
Not sure what the fast idle valve is but the old block does not have this extra coolant line. I'm going to give those diagrams a shot tomorrow. I think maybe I have the starter wires backwards or something dumb... I guess not too many people have the old 88-91 gen civics. Not getting too much insight here.. Wish me luck, I may be losing my job if I can't get it fixed by the time this weekend is over. Updates coming soon....
Old Dec 9, 2007 | 04:16 AM
timmytim's Avatar
http://i166.photobucket.com/albums/u...ah/diagram.jpg
Can anyone read this damn electrical crap? [:@]
Old Dec 9, 2007 | 04:56 AM
timmytim's Avatar
Alright so I'm a freaking retard folks! RonJ you've been an awesome help dude. My solenoid wires were backwards. (Had power going to the smaller side of the solenoid)... I reversed it and the car is turning over and engaging properly.It was dead so I didnt get much, but it is functioning properly.Im waiting now for the battery to charge up a little from jumper cables before I attempt to start it again. Updates coming soon!!!
I'll probably be back with full juice to the battery and whining that it's turning over and not firing now. ---- BRB!
Okay, got full juice and still no fire. I get a spit from the intake and that's it. Any suggestions??
Old Dec 9, 2007 | 05:26 AM
ORIGINAL: timmytim
Alright so I'm a freaking retard folks! RonJ you've been an awesome help dude. My solenoid wires were backwards. (Had power going to the smaller side of the solenoid)... I reversed it and the car is turning over and engaging properly. It was dead so I didnt get much, but it is functioning properly. Im waiting now for the battery to charge up a little from jumper cables before I attempt to start it again. Updates coming soon!!!
This is great news! I am so glad you figured out the problem.
By the way, I don't think the starter circuit diagram in diagram.jpg matches with your year Civic.
Good luck with ignition!
Old Dec 9, 2007 | 05:29 AM
timmytim's Avatar
Ahh screw wiring diagrams, im a huge fan of plugunplug :P Also, the car has some funk smelling steam/smoke after it spits. it doesnt smell like gas or oil... ;/
