Grinding noise?
Old Aug 11, 2008 | 05:20 PM
Cody1026's Avatar
Question Grinding noise?
I have a 1997 civic EX or SI(Canadian model) i just changed the clutch and put in a stage 1 ceramic clutch. The problem is, when i release the clutch and let idle it does a weird almost like grinding noise in the tranny or something. It also applies for when i am decelerating. Although when i press the clucth in, the noise stops ??? Can anyone help with the prob?
Old Aug 11, 2008 | 05:44 PM
Pull the clutch lever toward the cylinder and see if the noise stops. If it doesn't it's from a bearing inside the transmission most likely. Did you refill the fluid? What kind of fluid did you use? It is not too hard to open the transmission up and change the bearings without doing a total rebuild.
Old Aug 12, 2008 | 08:00 AM
Impreza WRX's Avatar
My Cavalier does that, but in my car, it's normal for the car to do it. It's called the "Getrag rattle" and happens to random vehicles and setups. I went for Carbon Kevlar
vdog
Sep 3, 2005 05:33 PM
bvideto
May 12, 2005 07:53 PM
rex_99civicEX
Apr 18, 2005 11:32 AM
silvercivicsrs
Mar 11, 2005 10:10 PM
foozball
Jun 14, 2004 03:41 PM
