Has anyone done a timing belt??
Old Mar 21, 2012 | 08:27 PM
TyBardy's Avatar
Default Has anyone done a timing belt??
I am (likely) going to replace the water pump and thus the timing belt either this weekend or next. The 98 LX I just bought is leaking from what appears at the moment to be from the water pump. This will actually be the first time I have attempted a timing belt at all, let alone on a civic so I am open (in need) for pointers and help for this one.
Side Bar - It is amazing how cheap parts are for these cars. I did a water pump on my tahoe a few months back that ran me something like $300 for the part alone. Not including all the DexCool I had to replace. This unit is $50!!! ($28 for valuecraft but I think I will get a better unit than that).
Old Mar 22, 2012 | 08:42 AM
axis11's Avatar
A timing belt job is not that difficult. Do a search on previous post and look at some youtube videos, get the right tools and your all set to go.
Old Mar 26, 2012 | 05:20 PM
TyBardy's Avatar
well i have done some research, which was good because now i have more questions...
It looks like I need a special tool to remove the harmonic balancer. Anyone know which tool this is?
Old Mar 26, 2012 | 05:51 PM
You can just spin the bolt out with a good impact wrench (standard right hand thread, turn ccw to loosen). If you're going to try to do it by hand (not recommended) you need the special tool-- crank pulley holder-- to hold the pulley still and a long lever to turn the bolt.
Old Mar 27, 2012 | 07:45 PM
TyBardy's Avatar
how do you get an air impact into that location?? I haven't got started yet, but I do not see how I would get my air impact into that small of a space?
Old Mar 28, 2012 | 03:54 AM
Jack up the car and take the left front wheel off. Remove the plastic fender liner. Then it is easy to reach.
Old Mar 28, 2012 | 03:14 PM
2012 Si's Avatar
I did it once on my old 93 LX. It was a 5-speed so I blocked the flywheel with a long screw driver to keep the crank from turning. I used a long breaker bar on the socket to get it loose.
I'd use a Honda pump because I know they last a long time.
briceman124
Nov 7, 2011 05:36 PM
and_so_we_went
May 5, 2008 05:38 PM
kyleag89
Dec 27, 2007 02:13 PM
Basil
Aug 13, 2007 06:52 PM
scamil87
EK Swaps
Feb 6, 2006 09:40 PM
