Having a bizarre issue with battery and idle, please help
Old Jan 17, 2020 | 04:48 PM
91civicbase's Avatar
Default Having a bizarre issue with battery and idle, please help
I have a 91 civic base with 1.5. Was driving and the engine started bogging down intermittently. I checked the plugs, wires, distributor internals, battery connection and sensor connections. I received no check engine light. I also replaced the fuel filter. When I start the vehicle, it cranks and runs just fine until the engine warms up and then it starts misfiring like sumbitch. When I quickly turn the key back ACC then back to run the engine comes back up to normal idle, and can accelerate rpms without issue, but only for a short period. When it's misfiring, if I disconnect the negative battery cable, the rpms come back up to normal idle, but bogs down if given gas. Also, if I turn the high beams on, the a/c fan and radio on, the engine runs perfectly. I've exhausted my knowledge and look to you fine people fore help. Thank you for any advice you send my way.
bustersmom11
Jun 3, 2011 03:11 PM
vladivostok
Dec 30, 2010 03:44 PM
trustdestruction
Jul 6, 2009 01:14 PM
eddy_7
Feb 26, 2008 02:55 AM
grncivicvtec
Jan 19, 2005 08:29 PM
