Check engine light wont give code
Old Jan 19, 2020 | 11:24 AM
Itssoeasy's Avatar
Default Check engine light wont give code
I have a 95 civic EX with the check engine light on tried doing the paper clip to sort out the obd (I think that's what its called) to make the check engine light blink and give me the code but it just stays on solid wont blink I removed the 02 sensor to make it give me the 02 sensor code but it just stays on solid the car has a strong smell of fuel when it's on after a while it does sputter and sometimes turns off I also removed the oil cap and smelled it and it does smell like fuel What would resolve the check engine light to give me the code?
Old Jan 20, 2020 | 02:58 PM
Code 0 is a solid light
Old Jan 20, 2020 | 10:41 PM
Itssoeasy's Avatar
Looked online a code 0 is the ECU so I have to get a new one
Old Jan 21, 2020 | 04:41 PM
If you have a buddy with a similar car (92-95 only), you could try and use theirs as a quick test to ensure it's the ECU rather than the wiring to the ECU.
Old Jan 21, 2020 | 08:40 PM
Itssoeasy's Avatar
My brother has a 95 civic so we tried out his out and with his ECU the check engine light isnt on
so it's the ECU that's bad?
Old Jan 22, 2020 | 03:11 PM
If you swapped only the ECU and the code is gone, I would think it's safe to say that yours is bad. You've isolated the problem during the ECU swap.
davis2012
Aug 14, 2013 12:16 PM
goguendo
May 3, 2010 12:10 PM
r5dualtypen
Nov 29, 2007 09:26 AM
94civicexvtec
Dec 15, 2006 11:00 AM
Talon585
Dec 19, 2005 07:32 AM
