Check Engine light on AutoZone code P0135
Old Dec 14, 2006 | 08:19 AM
94civicexvtec's Avatar
Default Check Engine light on AutoZone code P0135
Can anyone tell me what code P0135 means. AutoZone hooked up to my car and this is the code they read. They claim the malfunction exists in the heater circuit for oxygen sensor 1 in bank 1. I was told not to believe what AutoZone always tells you.
Old Dec 14, 2006 | 08:32 AM
mxs's Avatar
mxs
Default RE: Check Engine light on AutoZone code P0135
they are not lying, that's really what code PO135 means.
Old Dec 14, 2006 | 08:34 AM
cderalow's Avatar
indeed...
means the O2 sensor mounted right near the engine is faulty
(been there, replaced that)
Old Dec 14, 2006 | 09:32 AM
if i don't replace it right away will it effect the performance of the engine?
Old Dec 15, 2006 | 10:34 AM
Flyboy's Avatar
The heater in the O2 sensor heats the O2 sensor element so it will read the exhaust quicker so the computer can lean or richen the mixture for best economy and performance faster than by letting it heat up on its own. I would think as long as the O2 sensor itself is working ok there shouldn't be a problem. The worst case is that your cat. converter will get possibly a little more richer mixture going through it during warm up and that is not too good for it.
I would look into having it replaced. Depending on where you live, (I live in California) it most likely won't pass the smog test if your computer is getting any codes.
Hope this helps.
Old Dec 15, 2006 | 11:00 AM
cderalow's Avatar
it will effect fuel economy as well as emissions...
get it done, it's a relatively cheap fix ($100 i think)
milhouse
13
Apr 29, 2012 02:12 PM
sasmit09
Apr 12, 2012 09:25 AM
joeyf150
Oct 21, 2011 03:06 PM
houstonewyork
Apr 7, 2009 04:45 AM
shortlid
Feb 19, 2006 10:15 AM
