header question
Old Feb 20, 2008 | 03:40 PM
2civics's Avatar
Default header question
ive got two civics on my 98 2dr its my runner and it has a d16y7. on my 99 there is a d16z6 and it has a dc header on it wich i want to take off and put on my 98 will that work
Old Feb 20, 2008 | 04:19 PM
FlipHKD720's Avatar
Default RE: header question
what 98 model do you have? Yes, the header will atleast bolt onto the block, mid-pipe line up might be questionable, but i think D series exhaust manifold bolt patterns are pretty universal. If its a d16y7, the header on the 98 will delete the cat, but if its an EX you should be fine.
Old Feb 21, 2008 | 11:53 AM
2civics's Avatar
i believe its a dx no power windows or locks
Old Feb 21, 2008 | 11:56 AM
FlipHKD720's Avatar
Do you have the stock exhaust manifold on the 98? Check and look at it and if theres a big bulge in it, thats the catalytic converter, in which case you'd need to have a unviersal cat welded somewher ein the exhaust to keep it emissions legal (the new header won't do anything for emissions)
Old Feb 21, 2008 | 11:59 AM
2civics's Avatar
what if im not to worried about being legal will it work
Old Feb 21, 2008 | 12:05 PM
FlipHKD720's Avatar
yes
Old Feb 21, 2008 | 12:14 PM
2civics's Avatar
the motor thats in the 99 is not the original motor by the looks of it. somebody put the vtec in it without the vtec ignition and i think they fried the motor
Old Feb 21, 2008 | 12:16 PM
FlipHKD720's Avatar
does the 99 have a d16z6 in it? If so then no thats definitely not hte original engine, they stopped putting them into cars about 95.
Old Feb 21, 2008 | 12:20 PM
2civics's Avatar
yeah thats the motor. somebody didnt do a very good job of installing it. when we did a compression check all the cylinders varied alot
Old Feb 21, 2008 | 01:29 PM
FlipHKD720's Avatar
well that could just be a bad engine too.
