Headlight help!!
Old Oct 13, 2007 | 10:29 PM
Xanderjoseph's Avatar
Default Headlight help!!
i went through and looked at the other headlight threads. but none really helped. i have a 2000 EX. and my driver's side headlight shines way up in the sky. it looks like there are 2 little gears behing the light. and one of them says L/R. im thinking thats the thing that turns the light on the horizontal axis, while the other is vertical. only problem is when i turn these gears, nothing changes. the light stays in the same spot. any ideas on how to fix my light?
Old Oct 14, 2007 | 07:02 AM
kinosh's Avatar
Default RE: Headlight help!!
I would take off the light and clean and lube thehardware that secures the light. It's possible that you have rust that keeps the X-Y adjustments from moving.
Old Oct 14, 2007 | 08:48 AM
Stimpy's Avatar
look at the mounting brackets for the entire headlight unit as well, sounds like it got knocked or something
Old Oct 14, 2007 | 08:26 PM
ok ill check that out thanks
brokenarmboy19
Jan 15, 2007 06:31 PM
rmiller28
Jul 31, 2006 08:18 PM
m00chness
Jul 18, 2006 08:54 PM
civic90power
Jun 12, 2006 06:12 PM
dj_ipirate
Oct 31, 2005 09:12 AM
