headlight switch
Old Dec 12, 2006 | 01:53 PM
jko7's Avatar
Default headlight switch
I'm still looking for help with the headlight switch. Does anyone know if you have to replace both sides? Or can you just replace the headlight switch and not the wiper? If so, do you have to remove steering wheel or can you get to it easily? thanks for the help
Old Dec 12, 2006 | 10:40 PM
Dr Talon's Avatar
Default RE: headlight switch
Removing the wheel makes it easier. After that, remove top plastic cover from steering column, there is a black box where the arms are attached. Remove the cover of the black box (caution: springs) and i think for some the arm is attached with a bolt and some a pin with a snap ring holding it in place. Remove that pin/bolt, you should now be able to slightly remove the arm because of the wires going to it. Some year civics have direct wiring and some have a plastic connector. Either way, it needs to come out and be replaced. Replace the same way it came out and test.
Old Dec 13, 2006 | 03:19 PM
mcmichael13's Avatar
if you need the switch, i have one for a 92-95... i dont know if it fits other years...
Old Dec 15, 2006 | 09:12 AM
jko7's Avatar
i do need one. how much is it?
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
roanoke10
May 15, 2007 08:32 PM
kennycivicparts
Mar 1, 2007 05:31 PM
jko7
Dec 11, 2006 10:28 AM
zeppelinfire05
Sep 1, 2004 02:38 PM
