heater/ AC not working
Old Apr 11, 2009 | 05:45 AM
jrestrepo589's Avatar
Default heater/ AC not working
my heater and acdont work on my 96 civic ex 4dr. i turn the thing to 1,2,3,and 4 and it doesnt even turn on at all...what do you guys think it is? i have no idea...it just stopped working all of a sudden
Old Apr 11, 2009 | 06:02 AM
Find the fan motor under the right end of the dash. It has a 2-wire plug on the bottom. Leave the plug plugged in and measure the voltage between the two wires with the key on II (normal running position, it is not necessary to actually start the engine) and the switch on 4.
If you have 12 volts, yet the fan is not running, the motor is bad.
If it is zero volts, measure from each wire to ground. If both are zero, check the fuse and relay under the hood. If both are 12 volts, it's the fan switch or the resistor. I think when the resistor is bad though 4 will still work but the slower speeds won't.
Old Apr 11, 2009 | 06:32 AM
dito exactly what id recomend! if you have power at the blower simply kick the motor a few times and if it comes on that just means its definatly going out shortly.LOL i had to kick my motor in my 94 civic for about a week until i had the cash to replace it. luckely on pay day then it went out and kicking it didnt make it come back on since it completly fried then. LOL
replacing the blower is very easy!!!!
either aftermarket blower and cut the wire harness or buy a oem replacement and just unplug and plug the new wires in.
and if you want oem parts i got some for ya i got the resistor pack and blower from my 96civic i have for sale... but thats only if you need them
chloiebear21
Dec 24, 2012 11:46 PM
safo
Nov 18, 2008 10:57 AM
stevel
Jul 1, 2008 12:36 PM
chrisroug
Oct 2, 2006 11:36 AM
