Heater assembly installation
im having alot of trouble installin the heater assembly it looks like this
i was told on im to remove the dash so i did that heres some pics and yes the glove box and the bracket was removed al;ong with it my car currently has no a/c nor heater stuff at all whatsoever all the parts you can think of on it its not in there. im rebuilding the a/c Heater system
when i try to put it in it doesnt fit i have tried so many angles to put it in but it wont budge please help! sorry for the giant pix i dont know how to turn down the resolution on my camera
Also if you have a car that is working stock but with no A/C, you can add A/C without changing the heater box or removing the whole dash. The A/C parts are designed for ready "bolt on" installation through the glove box opening.
okay im not sure how to remove the whole entire dash i need instructions on it i also was told to remove the srs unit im going to do that as soon as i get back home anyways my car never had this part it basicly had nothing at all whatsoever
Here's what I remember about dash removal, but I may have left a few things out. It is mostly obvious what to do. For example whenever wires are stopping you from removing something, unplug them.
* Make sure the power windows and sunroof are closed in case you need to leave the car outside while it is taken apart. The electrical wiring will be disconnected.
* DISCONNECT THE BATTERY. I put this as a separate step because it's very important.
* Remove the glove box.
* Render the passenger airbag safe by unplugging it and plugging in the red shorting connector which should be nearby. Remove the airbag unit and set it away from the car and people, facing up. Also put the safety on the driver's airbag, the plug is under a cover on the steering wheel. You will not need to remove the driver's airbag from the car. You do not need to do anything with the SRS control module.
* Remove the center trim (upper and lower), radio, heater control panel, hazard light switch, instrument panel trim, and instrument cluster.
* Remove the 4 bolts holding the steering column to the sub-frame and lower the steering wheel/ column assembly down. Removing the driver's seat may be helpful to have more space.
* Remove the bolts holding the dashboard in. I know there are 3 on the top: one at each end under covers you can see when the doors are open, and one under the center defroster vent (pry the vent grille out). Not sure where the other ones are.
tgs
Mar 28, 2010 07:12 PM
kennycivicparts
Aug 6, 2008 05:32 PM
