heater problems
Old Oct 8, 2009 | 01:32 PM
hondacivcDX1989's Avatar
Default heater problems
okay so my heater does work but i have to turn the key back a little bit in order for it to kick on. this is a problem when i need the heat for the defrosters.
Also it is hard to turn it back while the engine is running or it will turn off. It seems the radio works in the same way.
anybody else has this happened with your car and/or do you know how to fix it? Ive checked the fuses they are all good.
Old Oct 8, 2009 | 01:58 PM
Your ignition switch is defective. Replace it. The heater, radio, wipers, etc. have a separate contact in the switch than the ignition itself.
Old Oct 8, 2009 | 02:11 PM
thanks for the quick reply, it was coming down to that i just wanted to make sure i was in the right direction.
Ordered a new switch for 29.99 with a lifetime warranty.
tgs
Mar 28, 2010 07:12 PM
gandalf386
Feb 9, 2009 04:32 PM
jrestrepo589
Dec 26, 2008 03:41 PM
romic00
Dec 3, 2006 08:06 PM
NorCalRice
Feb 13, 2005 04:48 PM
