Help
Old Oct 24, 2018 | 07:48 PM
Derek Robson's Avatar
Default Help
So I have this 95 civic DX .cold start is fine .the minute it gets warm it starts to choke out around 30mph when i stop or let it sit to long at idle or when it's warming up it just dies. Then it usually won't start until it cool . If it does, it's because I cranked it over till the battery almost dies .them when it does it blows thick white smoke If I put it in nuteral it sometimes helps at idle but mostly does nothing. Check engine light comes on to .I've replaced tps, map, plugs, and battery. I my obd1 doesn't look like what I keep seeing so I'm pretty sure Im looking at the wrong thing .I don't want to spend anymore until I can check codes .need it running asap .got a lady and 1 year old at home and I can't get to work
This is all I see that looks similar and it's plugged in so....
91civicbase
Jan 17, 2020 04:48 PM
brian_m
Jan 25, 2012 12:08 PM
vladivostok
Dec 30, 2010 03:44 PM
larsenracing
Apr 21, 2006 02:25 PM
kjreinha
Aug 1, 2005 03:07 PM
