help civic heating up
Old Feb 26, 2013 | 04:25 PM
w714icked's Avatar
Default help civic heating up
hi everybody im new here and using google i discover this great forum maybe u guys can help me i have a 94 honda civic dx my car has been loosing coolant i first replace the thermostat it kept getting hot so i replace the water pump i bleed the system out so i got all the air out did a compression test i i taught it could be the head gasket but it held the pressure just fine after that i took a trip to another city got on the highway and it got hot again and when i was slowing down the temperature gauge move down like it was cooling so i notice that it gets hotter in the highway faster than on the street also it starts blowing steam thru the reservoir any help would be appreciated
Old Feb 26, 2013 | 06:35 PM
conceptualpolymer's Avatar
Your head gasket could be leaking only under load. I believe a radiator shop can test your coolant for signs of combustion gasses. Some other possibilities:
Bad radiator cap
Thermostat is in backwards
Old Feb 26, 2013 | 07:11 PM
Get the radiator as full as you can. With the engine COLD, start the engine with the radiator cap off and rev it. If coolant and / or air blow out of the radiator, the head gasket is bad.
Old Feb 27, 2013 | 09:38 AM
Turtlegrip's Avatar
sounds like HG, mine was bad and it passed compression AND leak down test (according to a mechanic, how knows if he really did the test)...
Old Mar 1, 2013 | 10:34 AM
w714icked's Avatar
ok thanks everybody for the quick response ill star with the cheapest radiator cap and check the thermostat and test radiator fluid than head gasket ill keep u guys posted thanks again
91sihatchback
Apr 14, 2011 07:55 PM
hondarob
Oct 23, 2007 05:12 PM
kingTOM
Aug 19, 2007 05:21 PM
ic892003
Jun 27, 2007 11:19 AM
stylus
Jun 11, 2006 07:46 PM
