Help D16y8
Old Dec 1, 2010 | 11:17 PM
Originally Posted by Civic T
Is it true that improper throttle cable adjustment will affect auto trans operation?
throttle cable no, kick down cable yes. but you gotta be more specific on what type of trans problems
Old Dec 3, 2010 | 03:00 AM
Civic T's Avatar
I have the auto trans with the torque converter lock-up. At about 60mph, I can feel the lock up kick in like an overdrive. The rpm's drop and it's fine, however when I set my cruise control or hold that speed manually, the lock up kicks in and out multiple times and is becoming bothersome. I read here that a misadjusted cable (too tight or too loose) will cause the throttle sensor to read the wrong butterfly position. I did an adjustment on it yesterday( it was too tight) left a 1/2 inch play like the repair manual says. Going to try it today on the hiway. Thanks for your help. If you have any other insight, please let me know. Also, is there a way to disable or put a switch on it so I can engage it maunally over 65mph?
skyvang
Jun 19, 2009 10:23 PM
Ek98
Nov 30, 2006 12:43 PM
satanracing
EG Swaps
Jun 28, 2006 02:58 PM
123r
Aug 29, 2005 12:55 AM
