HELP!!! HX wont start!!!!!!!
Old Apr 20, 2008 | 01:37 PM
99HX's Avatar
Default HELP!!! HX wont start!!!!!!!
So i came home last night around 6pm. Turned my 99 Civic HX off and went inside. 30 miuntes later I needed to leave again so I went into the car and it wouldnt start. Radio works fine, light, engine lights all turn on. but engine wont start. there is no cranking. i do hear a very very slight humming when I turn the key but other than that nothing. the battery connections both are firm. i tried jump starting but as I suspected that did nothing. also, on the left side of the dash there is the light dimmer **** and immediatly to its left is what on most other civic models is the cruise control button. On my HX there is no button instead there is a portruding light which now flashes red, even when car is off. this light had turned solid red a couple weeks back, even when car was off. does anyone know what this is for? my neighbor thinks it might have something to do with the security system but the hx models dont have stock security or keyless entry as far as I know. and even if it did I never used anyhing besides key to lock/unlock car.
Old Apr 20, 2008 | 01:42 PM
Default RE: HELP!!! HX wont start!!!!!!!
If you are not the first owner, the previous one may have installed a security system with a kill switch. You may need to trace wires from the red light to figure it out.
Old Apr 20, 2008 | 01:48 PM
99HX's Avatar
i am the second owner. so you think its a secuity system problem? why would kill switch activate to begin with? sorry im not very auto saavy i have no idea how to trace. is there something in fuse box i can play with? my neighbor sugggested this but he said he did not want to make it worse so hes not gonna mess with it.
Old Apr 20, 2008 | 05:40 PM
99HX's Avatar
ok im new at this but i took off the panel. there is a blue and red wire coming from behind the light which go towards the engine but i have no idea where to. also i managed to find a black box with the name KARR on it. google this and found out its an alarm system. you were right. should i disconnect this?
Old Apr 20, 2008 | 06:55 PM
cyberx32's Avatar
if you never used it then yes just disconnect it and you wont have an alarm anymore
Old Apr 20, 2008 | 07:00 PM
gwl's Avatar
gwl
Since you don't have a remote and only used a key to lock and unlock your doors, you may want to look for a valet switch. A valet switch is used to disable an alarm. I would get a wiring diagram for your car before you want to dig into your wiring. Another option is to ask a tech at a stereo/alarm shop to see which wires they would use to disablethe start mode when they install an alarm.
Old Apr 22, 2008 | 06:22 AM
Jesse69's Avatar
Your 99 HX has cruise control? - My manual 99 HX doesn't!
If the problem is your starter Accel has an Ultra Light Starter for it!
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
nic95civic
Oct 28, 2005 11:40 AM
92civicb16a
Sep 5, 2005 09:19 PM
MaD91cIv
Aug 8, 2005 02:40 PM
