Civic wont Start PLEASE HELP
Old Aug 7, 2005 | 04:11 PM
MaD91cIv's Avatar
Default Civic wont Start PLEASE HELP
I have a D15 in my car right now Im saving for a B18a but I need to get a few more parts and need my civic running again. It was running like poop after I put the ignition module in the distributor but it was still running. Heres the story I was driving home from work with the same old sputtering crap I have been dealing with ever since I did my head gasket. It sounds like it is out of time but I had a garage do the timing as I dont have a timing light and still it ran like crap. I came up to a stop light and it started puttering more than it has before, I could barely keep it running. I tried starting it and it putters like its about to start but doesnt and also makes a weird sound like something is grinding right at the end but it still turns over.
Now I need this car for work so that I can save the last little bit before I can afford my b18. I really need help so any suggestions you could offer would be helpful.
Thank you for your time,
Tyler
Old Aug 8, 2005 | 02:40 PM
Kappa22's Avatar
Default RE: Civic wont Start PLEASE HELP
Worst case scenario, I'd say bent valve(s) or a burnt out main bearing. Bent valves are more likely, since you recently had the head off.
9T6EX
Mar 23, 2012 03:44 PM
3daddict
Nov 10, 2011 10:39 AM
CustomCivicClubCCC
May 23, 2011 12:35 PM
bmelloh
May 16, 2009 08:01 PM
nic95civic
Oct 28, 2005 11:40 AM
