2000 civic dx wont start please help
Old Nov 9, 2011 | 04:05 PM
3daddict's Avatar
Default 2000 civic dx wont start please help
hi guys sorry for posting ive searched as much as i could, i have a new born at home so time is very rare right now..
ok i have a 2000 civic dx with 110,000 miles, drove home from work everything was fine got home parked car and went to leave at 4am for work and it wouldn't start.
it cranks fine but no sounds that it will fire, i tried some starting fluid still not a thing, checked spark plugs they looked a little worn so i replace all 4 and checked all 4 for spark, spark is good. i hear the fuel pump go on with the key and loosened the bolt going to the fuel rail and its getting plenty of fuel there, i checked the volts at the injectors and im getting 11.8 at each , did a compression test and its 170-160-155-170, timing belt is still intact i can see the cam spinning through the oil fill, the only thing i dont have a tool to check is the timing degrees i dont know what else to do, i have never seen a check engine light since i own the car (3 years), the only problem i ever had was a rusted out muffler which was swapped for a new muffler
any ideas?
thanks in advance
Old Nov 10, 2011 | 10:39 AM
droopy128's Avatar
Only thing I can think of since you did all the preliminary check off is either the main relay or ignition switch.
9T6EX
Mar 23, 2012 03:44 PM
CustomCivicClubCCC
May 23, 2011 12:35 PM
bmelloh
May 16, 2009 08:01 PM
nic95civic
Oct 28, 2005 11:40 AM
MaD91cIv
Aug 8, 2005 02:40 PM
