Help with problem?
Old Apr 6, 2005 | 08:42 PM
lj1102's Avatar
Default Help with problem?
Hi, I'm new to these boards. I am having a problem with my wife's 2000 ex sedan. The front end seems to be making this vibrating/humming ? noise whenever I am backing down a hill or turning the steering wheel all the way and accelerating. My guess is that the cv shafts or drive shafts are going? The car has 43,000 miles. Any suggestions or help would be greatly appreciated. How can i check if the shafts are bad?
Thanks
Old Apr 6, 2005 | 10:49 PM
94VTECoupe's Avatar
Default RE: Help with problem?
Don't worry about the sound it makes when you're backing up. That's normal because the reverse mechanism has a little idler gear in there that causes a noise. However, the turning problem sounds like a CV shaft going out. Does it make a clicking sound kind of? If does then it is your CV's. Just take it in to your local mechanic and you can get it replaced for pretty cheap.
Old Apr 7, 2005 | 05:16 PM
rzimmer11's Avatar
Yea all civics make a humming sound in reverse
djt
Jun 21, 2008 07:48 AM
redlines4us
Aug 22, 2006 05:49 AM
Jas10hon
Jul 4, 2005 10:35 PM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
