Help with removing headlight & front bumper on '91 Civic HB
I'm trying to replace the AC condenser but I'm having some difficulty removing the front bumper. I havea Haynes manual but the diagrams & instruction aren't very good. Has anyone done any of these before or have a good diagram of the headlight mounting bolt locations? Is there a trick to removing the headlight to access the bumper spacer piece? I can't get to the bolt that's securing this because the headlight is in the way.
Any suggestions?
Any suggestions?
Been a while since I changed my condenser so I don't remember exactly what was involved, but I certainly didn't take the headlights or the bumper off. I think if you pull the radiator you can get the condenser out thru the back.
Anyway if you want to remove the headlight for some reason it has 4 bolts, the obvious two on the top of course and two on the bottom that come in from the side. The side bolts are removed by taking the corner marker light off and reaching thru there. The inside bottom bolt is a real pain to reach, best done with a 12 inch socket extension and socket u-joint.
CivicJay21
May 13, 2012 02:36 PM
theRDRman
Dec 1, 2011 05:45 PM
speechless33759
Jul 31, 2006 01:34 PM
1991, 91, bumper, civic, civicremoving, diy, front, hatchbackhead, hb, honda, instruction, light, removal, remove, removing
