HELP: suspension or coil over failure?
Old Jun 24, 2010 | 09:36 PM
powerhousing's Avatar
Default HELP: suspension or coil over failure?
So today I was driving on the road and I hit a part of the road that it had a small ditch in it. I was going about 40mph and I felt a BUMP (more like a "dunk" sound), since then, whenever I hit like a small bump or something. Now the drive feels like I'm driving on a flat tire; it drives and all but I can feel a little wobble and whatnot. At least it's only the right side that feels that way but, what do you think guys? Do you think I broke the suspension or coil over? I'm going to take a look tomorrow, but I was wondering what you guys think. THANKS
Old Jun 24, 2010 | 09:44 PM
probably bent something or the tires may need to be rebalanced
Old Jun 24, 2010 | 10:02 PM
That might be right, I have a spare tire so I'll give it a try. While I'm changing the tire, I could check around and see what's wrong. Thanks!
Old Jun 25, 2010 | 08:05 AM
civicexracer's Avatar
It's possible you hit the ditch hard enough to bend the wheel a bit. This will cause you wheel to be unbalanced and it'll wobble/vibrate. This would happen more so when moving between certain speeds(say 40mph-70mph). If you can a noise or wobble feel only at certain instances like when going over a bump, then something else could have knocked loose or broke.
Old Jun 28, 2010 | 12:05 AM
I'll finally have time to find out tomorrow, but I do get a weird bump or noise on certain instances such as bumpy road. I really hope it's nothing major, I have so much to fix
vdog
Aug 25, 2005 01:56 PM
k2rad
Jun 24, 2005 02:25 PM
Struletz
27
Apr 3, 2005 12:36 PM
pimp95civ
Oct 6, 2004 01:14 PM
civicjuju
16
Sep 24, 2004 08:25 PM
