help with a timing belt 88 civic/ engine
Old Sep 24, 2009 | 07:33 PM
wireyanker's Avatar
Smile help with a timing belt 88 civic/ engine
Ok, so were driving down the road about 50mph and the belt breaks. i have the end of the engine opened up down to the pulley on the bottom which is said to be a chore to get off. my question is this car is not worth much granted but what percentage is there that the valves etc. are toast in your opinions? cam will turn with a driver and engine moves. i think it is the standard is it 1.8 l engine with about 160000 miles on it. am i wasting my time?
Old Sep 24, 2009 | 07:43 PM
you should be ok.. what model is the civic.
best way to tell is get a new belt and put it in time and try, if its bad then take belt off and return(clean) and try to find a new head.
Old Sep 25, 2009 | 03:40 PM
wireyanker's Avatar
Default it's a civic dx 4 dr.
is that enough information?
Old Sep 25, 2009 | 04:03 PM
wireyanker's Avatar
D15B2 engine
Old Sep 25, 2009 | 04:21 PM
you should be ok just get a new timing belt and put it on.i also suggest since you are there replace the water pump also.
smackpower
Jan 13, 2024 01:42 AM
Kyle700
Sep 18, 2014 07:44 PM
cb14sar
Jul 17, 2013 09:45 AM
tim.ocallag
Sep 6, 2012 09:46 AM
pippo
Jan 26, 2010 02:40 PM
