HELP!!!! wiring nightmare with supercharger and vtec controller
Old May 24, 2012 | 12:46 PM
trcook's Avatar
Default HELP!!!! wiring nightmare with supercharger and vtec controller
Hey guys. Im in way over my head here. I need mad help. I have a 2000 ex that the wire harness got wraped around the supercharger. All of the sensor wires are there just need to know where they go.
Old May 25, 2012 | 07:12 AM
Ok, so you are doing the supercharge swap right now? I assume the wires were not labeled at all when you pulled everything apart? I made that mistake while doing my H22 swap.
I assume you have a JRSC? Post some pics of the wire connectors you have laying around and the color wires which are going to them.
How is clearance with the strut tower wall and the P/S lines if you do have a JRSC? I had to make a bracket for the p/s return line since it was rubbing the belt during my install. Also, I had to bang in my strut tower wall for clearance, too :/
Old May 25, 2012 | 12:34 PM
I think the OP is saying that it was set up and running by someone else, but the wires have been damaged now.
Old May 25, 2012 | 03:15 PM
Turtlegrip's Avatar
if everything got ripped out but there is no damage to wires you are probably gonna have to get a engine wire harness diagram and go through the color codes on each plug to see where they go... if they all got ripped out and wrapped around a pulley then you are probably better off getting a new wire harness before you go through all that work just to find there are a bunch of broken wires which could possibly cause a lot more problems. You could also check continuity of each wire or if you are convinced it is fine just do what i first suggested.
Old May 26, 2012 | 08:40 AM
trcook's Avatar
Hey guys, Thanks for responding. I bought the car with the supercharger on it. Its a jackson racing supercharger with a boost/retard pot in the dash. If anybody has the wire diagrame for it could you send it to me?
I also have an vtec controller in my car that i need the wire diagrame for also.
Im going to buy a new wire harness for the engine becouse I dont want to wreck the ecu. Someone is looking for one for me.
But yeah I just need a jrsc wire diagrame that hooks into the ecu and the vtec controller wire diagrame.
I have the car running and let me tell you it got me addicted to the import cars now. I will try to post pics of it soon.
How many horse will this engine put out? with jrsc and 4-2-1 header and ram air kit. engine is D16Y8.
Thanks guys for all of the help.
Old May 26, 2012 | 08:42 AM
trcook's Avatar
i also need color codes for sensors for the car. any ideas where i can get that from?
https://www.hondacivicforum.com/foru...e-93337/page2/
Last edited by cvcrcr99; Jun 5, 2012 at 06:50 AM. Reason: added link to post instead of bumping a closed thread.
lilgreencivic
Oct 30, 2008 08:27 AM
h22hatch
Sep 7, 2006 05:06 PM
Cousens
Feb 26, 2006 04:57 PM
nightrider46
Sep 21, 2005 04:43 PM
deadcivic
Mar 9, 2005 09:25 AM
