Helpppp
Old May 16, 2011 | 01:55 PM
LILAZNCAR1992's Avatar
Default Helpppp
I have a 1996 honda civic sedan lx.
When i start the car and is idling it is so rough i feel like im in a earthquake. All the fluids are good, my exhaust manifold is cracked though. When i look at the engine with the hood up, the "whole" set up shaking. And when i try to accelerate it is so delayed...anyone help?
Old May 16, 2011 | 01:58 PM
Broken motor mount possibly. I am sure someone like "MK" will be in shortly to save the day.
Old May 16, 2011 | 01:59 PM
alright thanks, man if anyone had skype i could show them a live feed of exactly how this thing is running, !!
Old May 16, 2011 | 02:09 PM
Is your check engine light (CEL) on? Does it even work? It's the orange one that turns on with the battery light when you first start the car. Supposed to stay on for 3 seconds and then turn off.
Old May 16, 2011 | 02:13 PM
yes it has been on for like a week now. last time it was on my dad put the code reader thingy and he cleaned the sprk plugs and then it was good, its been driving with a little lag in the acceleration for a while, but now the car is like having convulsions. and by working yes i just cant drive very fast without the car seeming like its on something, literally shakes like a crazy addict
Old May 16, 2011 | 02:15 PM
Check the codes again. It almost sounds like it's misfiring if its shaking that bad.
Start it up and pop the hood. Pull one of the spark plug wires out a little. See if the idle changes. If all cylinders are firing, it should idle worse when you pull one of the plug wires. If it doesn't change, that cylinder isn't firing and I'd start looking at the plug wires or distributor. Check each cylinder one at a time.
(My wires recently looked perfect, but were actually toast, for example.)
Old May 16, 2011 | 02:19 PM
okay im going to do that but my dad has the reader not me
Old May 16, 2011 | 02:23 PM
The reader will tell you which cylinder is misfiring if that's the case. This way also tells you the same info. But if there are any other related problems, the code reader will be the best way to find out.
There is also a "paperclip" method to read CEL codes. Read up on that one here: ►►THE Check Engine Light (CEL) THREAD: HOW TO & CODES◄◄ - Honda-Tech
This will also be your friend. Free service manual in PDF format.
http://downloads.hondatech.info/Auto...e%20Manual.zip
Old May 16, 2011 | 02:28 PM
alright thanks ill try that :P
