High Idle After Intake swap
Old Aug 25, 2024 | 05:31 PM
Coreyma70's Avatar
Default High Idle After Intake swap
I did a 5spd swap on a 2000 honda civic ex d16y8, I used an skunk racing knock of intake and a 70mm throttle body. Currently the idle is around 2800-3000 I have a new ecu in the car I rewired the IACV from a 3 wire to a 2 wire and repinned at ecu I have checked this multiple times and have a brand new IACV. I have checked for vacuum leaks with brake cleaner with no luck, I replaced the throttle position sensor with a new one and tried the old one that was working before the intake swap. I have replaced the throttle body gasket with 3 different gaskets and adjusted the idle screw and removed the throttle cable completely nothing has changed the idle of this car, Im at a lose I dont know what is causing this high idle. Iv been searching the interwebs for months now with no luck, maybe you guys can point me in the right direction.
Fng
Aug 25, 2012 07:18 PM
tomp
Oct 14, 2011 12:02 PM
SDMOVER
Sep 29, 2010 08:01 PM
faifu27
May 29, 2010 05:19 PM
Dipsetcivic117
17
Jan 24, 2010 04:25 PM
