Is it possible to adjust the idle for a 1991 civic lx?
Old Oct 14, 2011 | 08:29 AM
tomp's Avatar
Default Is it possible to adjust the idle for a 1991 civic lx?
I have the car running fine, but now it seems it is idling just a little too high.
In park, it idles at about 1.25k RPM's.
Is it is as easy as a turn of the screwdriver somewhere, or should i just unhook the battery, and let the computer reset itself?.
Thank you!!
Old Oct 14, 2011 | 08:48 AM
droopy128's Avatar
There's a fast idle screw on top of the throttle, you can adjust it from there, but you should also clean out the intake too.
Old Oct 14, 2011 | 10:20 AM
Before trying to adjust anything, warm up the engine, unplug the IACV and see if the idle speed drops. If it does, the ECU is driving the IACV to increase idle speed and any attempt you make to adjust the throttle, etc. will be counteracted. The ECU is programmed to increase idle speed when the engine is cold, or when it thinks it is cold. Pockets of air in the cooling system or a bad ECT sensor will throw off the reading the ECU sees.
If idle speed does not drop with IACV disconnected, then too much air is getting into the intake somehow. This could be the throttle plate adjustment, throttle cable stuck or too tight, the IACV stuck open, or a vacuum leak. Anything that lets air into the intake will cause the idle speed to increase.
Old Oct 14, 2011 | 12:02 PM
tomp's Avatar
Just gave it a little turn to the left . The idle adjusting screw at the base of the throttle body.
It sounds fine!. thank you for the reply!.
cooltouch
Jul 24, 2012 09:06 PM
jackattack
May 9, 2009 04:14 PM
asechrist
Dec 22, 2008 05:49 AM
cuyo501
Mar 2, 2007 02:14 PM
chipottley
Dec 27, 2004 05:34 PM
