High RPM Stutter And Start Stall Issue
Old Oct 6, 2013 | 12:49 AM
KatoTragedy's Avatar
Question High RPM Stutter And Start Stall Issue
So i just bought a 92 civic with a d16z6 swap from a guy a couple days ago and everything was fine until i gave it wot for the first time. It went through the lower RPMS fine but after 5 grand it would start to stutter... I Chocked it up to not paying attention to the redline... I parked it to go into walmart n when i came back out it wouldnt start. It would turn over, run for a second then stall. I couldnt even keep it on by holding the gas pedal down... After about 10 attempts it started back up like nothing happened... So later i tried wot again and the same bucking happened. Half throttle n its ok though... fuel pump, filter or main relay?
Old Oct 6, 2013 | 05:55 AM
Anybody seen this before?
Old Oct 6, 2013 | 05:19 PM
It does sound like starving for gas, so changing the fuel filter would be a reasonable thing to try. With swap jobs you need to do a survey and find exactly what parts you have in terms of the ECU, etc.
Always resolder the main relay as a preventative measure. Main relay problems usually mean that it won't always start, but once started it will then run OK.
mudhenFUF
Jan 16, 2023 08:43 PM
Hondacipher
May 19, 2012 12:43 PM
MaximusFunk
Mar 13, 2012 08:26 PM
srvclapton
May 9, 2007 06:42 AM
deathincalabria
Feb 24, 2006 06:17 PM
