high rpms
Old May 27, 2006 | 05:14 PM
patcheway's Avatar
Default high rpms
i swapped a d16 out of a 1990 civic si into a 1992 civic that had a d15 now when i start the car it idles at 1500rpm and surges alot.the check engine light is on also i checked for vacuum leaks and found none so far.could it be the ecu being that i went to a bigger motor or does that matter?
Old May 27, 2006 | 06:14 PM
AgentofDarkness's Avatar
Default RE: high rpms
What is the code for the check engine light? You can adjust the idle by turning the idle screw on the throttle body after you have disconnected the Idle Air Control motor. Don't forget to reconnect the IAC.
Old May 27, 2006 | 10:07 PM
patcheway's Avatar
i looked under the kick panel on the passenger side to short the plug to get the code and i wasn't sure if it was the right one so i didn't do it. in the manual it says it should be a blue plug the only one i found was brown with a blue wire with a white stripe and a solid black wire. if you know this is the right one let me know so i can get the code thank you
Old May 27, 2006 | 11:33 PM
94DXProject's Avatar
I'm pretty sure you'll need the proper ECU for that engine.
Old May 28, 2006 | 01:12 PM
patcheway's Avatar
i fixed it it was the exhaust manifold gasket leaking thanks for your help
ninjastar
Sep 7, 2011 08:36 PM
tsghun
May 19, 2011 06:14 AM
Clean_Civic_98
Nov 5, 2010 09:52 AM
crz40
Mar 30, 2007 05:48 PM
sickcivic07
Feb 16, 2006 04:51 PM
