high temperature problem
Hello, I have a problem that maybe someone can help me with. I have a 95 Civic sedan and my temperature guage is reading high. I just dropped an engine in this car. Basically everthing has been replaced in the heating system except for the heating pump. temperature sensors have been replaced. I checked the temperature with a infrared beam and it came in at 180 degrees. They told me it was normal. I also changed the cluster in that I thought it would be a bad guage. I am done with any of my ideas. any suggestions.
In the new engine, did you change the water pump or thermostat, because you should always spend a little and do those.
Is it a bigger engine that you put in? Is the original radiator big enough for the larger engine?
kylebarbour
Sep 19, 2013 03:07 PM
civicshorty
Oct 21, 2009 03:47 PM
