Honda Civic 07 Right Engine Mount
Hi Everyone,
I have two questions
- My Civic 07 2dr makes sort of a grinding noise (as if something's boiling), whenever I start the first time after parking overnight. It does the same thing when I put it on reverse. At first the noises went away as soon as I put it on Drive, but lately I can hear some noise even when I put it on Drive. Here's the thing, those noises almost never come back after I have driven for couple of miles. But they come back again the next morning or whenever I am parked for more than 6-7 hrs.
So... I talked to a mechanic and he said my right engine mount must be replaced...is he right? and if so... he suggested getting an after market engine mount for $100 where as OEM costs $250... plus labor... so if he is right is it a good idea to get aftermarket engine mounts...
any kind of reply will be highly appreciated.. thanks
Hi Everyone,
I did find that the bolt on the back of the arm-support was just slightly loose so I tightened it as much as possible. I will find out later if it worked.
Did you resolve your problem?
Hi, I have the EXACT same car with the EXACT same problem! In the morning when the engine is cold I get noises from the passenger side engine compartment. These noises seem to change in type and intensity almost daily. It can be a tin-can vibration, a rumbling, buzzing, clunking or a combination. ALWAYS, after I've driven for about 5-8 minutes the noises STOP! One morning I started the car and then by simply placing my hand with a small amount of pressure on the engine mount support arm it caused the noise to stop. I assume that once the engine heat causes the metal in the support to expand and the rubber damper to soften that this dampens the vibrations.
waxandgo2004
Mar 25, 2015 10:23 AM
farmerjunglejoe
Jul 7, 2014 10:30 AM
alibarbar37
Feb 20, 2014 06:45 AM
hondac96
Oct 11, 2010 12:30 PM
