Honda civic EG horn
Old May 27, 2006 | 09:38 AM
phunky's Avatar
Default Honda civic EG horn
Hi guys, can anyone please help. my stock standard horn suddenly stopped working. Do i need to take my sterring wheel apart or something? ive checked all the fuses and there all good. Is there something that needs to be done like wiring? Its a EG model civic which is a late 91 model. Thanks heaps
Old May 27, 2006 | 06:45 PM
franz's Avatar
Default RE: Honda civic EG horn
check the fuse first. If that is ok, check to see that the horn is actually getting power with a voltmeter, it's more likely to be the horn or wiring than the steering wheel.
Old May 27, 2006 | 08:32 PM
jim9418's Avatar
"hot wire" the horn directly to the battery. If it works, then start like franz said with the test meter trying to find maybe a loose connection, fuse or something. If it doesn't work when it's "hot wired" try a horn from a car that you know works.
Old May 28, 2006 | 12:53 AM
phunky's Avatar
Thanks guys, The fuse has been looked at and working perfectly, how do i check if the horn is getting power? where is the wire i need to tap inot with the voltmeter? I like the sound of "hot wire" but where to i connect this to? one side to battery and the other one to? thanks heaps for your help guys
Old May 28, 2006 | 08:23 AM
franz's Avatar
there are two wires going to the horn, you just have to either put one of each to each side of the battery, or put a volt meter or multi meter on those wires whilst someone is actuating the horn button.
Old May 28, 2006 | 10:54 PM
phunky's Avatar
Thanks franz, but where do i find the two wires coming out of the horn? are these in the engine bay? thanks
Old May 29, 2006 | 12:27 PM
Stimpy's Avatar
your horn is just inside the lower grill in the front of your car, its on the passenger side but you can see it through the grill. there is a plug right at the horn with two wires leading out of it.
The easiest thing might be to go to an auto parts store and buy a replacement horn. Plug it in right in their parking lot and try to beep the horn. If the new one beeps, the horn was just broken, if it doesn't beep, return the new horn and welcome to the nightmarish world of automotive wiring
Old May 29, 2006 | 06:23 PM
phunky's Avatar
Thanks for the advice stimpy, I think it might be the horn b/c before it stopped working it wasnt as loud as id like. Did i need to get a honda horn or any aftermarket horn will plug in easily? Thanks
Old Jun 11, 2006 | 05:37 AM
phunky's Avatar
Ive found the horn wires and can see the horn beside the radiator, The only way in will be to disassemble my bumper. Is there an easier way to change the horn or to fix it without taking off the bumper?
Old Jun 12, 2006 | 12:26 PM
Stimpy's Avatar
Its pretty easy to take off the bumperThere are two bolts underneath the car, two screws just in front of the wheel wells (peel back the plastic), and 5 or 6 screws on the top. The bumper just pulls right off after you take those out.
Its probably not the only way to get at your horn, but it's sure easier than coming in from the other end.
(a hazy memory of a joke involving a guy getting his tonsils taken out rectally is comming to mind)
Zeblek
Aug 1, 2013 04:57 PM
myhondacivic1995
Aug 27, 2010 08:05 PM
Juans_MX3
Apr 7, 2010 03:38 PM
cyberx32
Oct 5, 2007 05:05 PM
civicexracer
Aug 4, 2006 05:23 PM
