Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
This is a very old debate. Honda Transmission Fluid is recommended for honda transmissions, that's all i'm going to state. There is a difference in automatic and manual transmission fluid.
I concur. the last time a shop, I trust, changed the MTF fluid while doing the timing belt also told me that according to Honda specs, 10W-40 was sufficient.
