How to bleed clutch lines?
Old Nov 26, 2006 | 04:23 PM
burnindesirez02's Avatar
Default How to bleed clutch lines?
I was told that i need to bleed my hydraulic clutch line but i cant find it and how do you check the gear oil?... please help me
Old Nov 26, 2006 | 05:01 PM
Default RE: How to check transmission fluid?
Help Please!!!
Old Nov 26, 2006 | 05:17 PM
Misha's Avatar
Are you talking about cable or about hydro line?
Car trim and year, too, please - this will help to answer your question.
Old Nov 26, 2006 | 05:18 PM
Hydraulic line. 93 Civic Coupe EX
Old Nov 26, 2006 | 05:46 PM
I kinda found the problem...my cylinder was empty...i didn't know it used brake fluid..but then how do you bleed it?
Old Nov 26, 2006 | 06:31 PM
Misha's Avatar
It's pretty easy if you ever tried to bleed your brakes. Procedure is pretty much the same - you press the pedal, open bleeding valve, close bleeding valve, release the pedal, start over. And watch that your fluid level does not go too low. The bleeding valve is located on the slave cylinder. It is located at the clutch housing, overlooking the radiator...
snowie
Mar 24, 2008 10:01 PM
roundyround
Feb 24, 2008 05:40 AM
Captain_Sl0w
Jul 23, 2007 10:46 AM
ELLAS1945
May 17, 2007 08:30 PM
NewClimber
May 6, 2007 03:53 PM
