Broke bleed screw
Old Feb 23, 2008 | 02:47 PM
roundyround's Avatar
Default Broke bleed screw
hey there guys, i got a bone-stock 94 civic.
when i pish the brake pedel, the thing goes all the way to the floor, so i thought "well ill see what happens if i just bleed the brakes"
I took off the pass. side wheel, and the bleed screw opened up real nice, very easily (i know they often seize)
so im thinking that this job should be quick and i wont have to wrestle with it. WRONG
i took off the drivers side, and tried to move the bleedscrew, and it snapped without any warning. there is still a little bit above the caliper.
I'll probably end up drilling and tapping all this in an attempt to save my caliper.
are there any tricks to getting something like this out?
past experiences?
thanks.
Old Feb 23, 2008 | 02:53 PM
95civic1.6l's Avatar
Default RE: Broke bleed screw
u could drill it out and retape it put a bolt in it that is the right size
Old Feb 23, 2008 | 04:47 PM
You may be able to insert a properly sized reverse thread bolt extractor (e.g., picture) into the hole of the bolt and unscrew the broken portion. Then simply purchase a replacement bleed bolt. Note that it may be necessary to drill the hole to a larger size before using the extractor tool.
Old Feb 23, 2008 | 05:48 PM
jamned's Avatar
I'd go ahead with what RonJ recommended. I've used one of those to remove several snapped bolts.
I'm not sure if this is a good idea, but you may want to clamp the brake line on this side. On the one hand, you may loosen the bolt and get lots of air bubbles in the system and brake fluid will drip everywhere. On the other hand, you might just damage the line by clamping it. Anyone else have input about this?
Old Feb 24, 2008 | 04:41 AM
yeah, im going to try to use an "easy out" bolt extractor today. do these thing use DOT 3 or 4 brake fluid.
4 in synthetic, and 3 is not i belive.
Old Feb 24, 2008 | 05:40 AM
DOT3 or DOT4 is fine.
powerhousing
12
Jan 15, 2012 03:41 AM
briceman124
Dec 29, 2011 05:26 AM
ELLAS1945
May 17, 2007 08:30 PM
NewClimber
May 6, 2007 03:53 PM
burnindesirez02
Nov 26, 2006 06:31 PM
