How to change ignition coil
Old Nov 24, 2008 | 09:36 AM
chikna's Avatar
Default How to change ignition coil
Hello,
Yesterday i drove nicely to work but later in the day when i start my car there is no spark ?? i tested it in all possible ways but there way no spark jezz
anyways, i did change to new spark plugs, plus i have new wires (4 months old) and same with distributor cap...
now i m not sure if my car wont crank because of bad coil? ignition starter or distributor??
if so, can u show me any diagram to change it.
my car is 1993 honda civic coupe DX 1.5Lit. Please help any feedback is appreciated.
cheers
Old Nov 24, 2008 | 12:00 PM
Does the fuel pump prime (listen for low humming sound for 2 seconds in rear when key is turned to ON position II)?
Does the distributor connector have battery voltage when the key is turned to ON position II?
Is the CEL ON?
Old Nov 24, 2008 | 12:10 PM
The engine does turn when you try to start it?
Also take the oil cap off and look inside while someone cranks the engine. Watch for the rocker arms to move. If the crankshaft turns but the valves don't move, the timing belt is bad. This will cause no sparks because the distributor doesn't turn either.
cruzncivic
Jan 28, 2007 09:03 PM
MarcB
Jan 23, 2007 08:20 PM
skimmy_jimmy
Sep 17, 2006 01:32 AM
arm97002
Sep 6, 2006 10:33 PM
ineedhp
Apr 17, 2005 09:50 AM
