How often do coils go bad?
Old Jan 1, 2010 | 07:35 PM
olcurt's Avatar
Default How often do coils go bad?
I replaced my daughters coil on her '96 Civic about one year ago. It is showing the same symptoms again. Is it a common occurence for these to go out?
Old Jan 2, 2010 | 01:04 PM
olcurt's Avatar
I replaced the coil and the car starts and runs fine again. Any ideas what I should look for in lengthening the life of the coil?
Old Jan 2, 2010 | 01:55 PM
GReddy_Civic's Avatar
Snail'n Admin
Hmm Im assuming you mean the ignition coil. If this is what you mean, I would consider either A) rebuilding the distributor or B) buying another distributor (used or new). Either way, there shouldnt be a reason for it to die within a year. was there a warranty on it? In addition, I would change the wires/plugs/dizzy cap and rotor. Also, if you are getting too much current to the coil, you may infact short it out
Old Jan 2, 2010 | 07:24 PM
^^ New wires cap rotor and plugs. If there is excessive resistance in the output circuit (especially the wires) there will be strain on the coil
Esquirrel
28
Mar 7, 2012 02:51 PM
mill$civic
Mar 8, 2008 07:08 PM
Silentcracker95
Jan 11, 2007 10:02 PM
ScoobyAddict14
Apr 4, 2006 05:10 PM
bobbytonic
Mar 16, 2006 11:44 AM
