How to replace a distributor?
Old Sep 16, 2005 | 06:02 PM
hiofcer's Avatar
Default How to replace a distributor?
Howdy. My 1993 Civic 1.6 will not start. It will turn over but wont fire. It does not have any spark. I'm not 100% certian but I think it's the distributor.
My question is: do I have to worry about screwing up the timing if i remove the distributor? It look like just 3 or 4 bolts and a few plugs. Anyone have a diagram? Can someone provide a breif step by step process.
Also what is the main relay and where can I find it on my car?
Thanks
Old Sep 17, 2005 | 08:17 AM
PhilStubbs's Avatar
Default RE: How to replace a distributor?
your distributor is 3 bolts and a couple plugs. when you put on the new one eep the cap off of it so you can turn it to line up with the cam. once its seated in fully then tighten down the 3 bolts and center the bolts in the slots. that will be a good safe place to have it so then you can take it to someone to adjust the timing correctly
Old Sep 17, 2005 | 08:51 AM
hiofcer's Avatar
Thanks alot for the information. I'm really hard up for cash and this information is invaluable.
Wouldn't the ECU automatically adjust the timing for me?
Old Sep 17, 2005 | 01:59 PM
PhilStubbs's Avatar
it only adjusts the advance. it doesnt do much for the actual timing of the engine. you have to set the distributor right when the car is at idle. the distributor is the only think telling the ecu the position on the engine so if the distributor is off then the ecu will be off too
Old Sep 18, 2005 | 07:24 AM
hiofcer's Avatar
the car is back and running guys. I replaced the whole distributor. this was not hard at all, except those two stupid plugs. not sure why i worrried about it too much. Thanks for the help guys.
Old Sep 18, 2005 | 08:04 AM
PhilStubbs's Avatar
its just fear of the unknown. the more you do things the more things you will feel better about doing. glad to hear its running again, good job
Old Aug 31, 2007 | 11:10 AM
Koireland's Avatar
So could I remove mine and change the bearings?
Old Aug 31, 2007 | 12:13 PM
PhilStubbs's Avatar
no, there are no bearings available for the general consumer. you will have to get another one if there is something wrong with your bearings. i know of a couple places that have them sort of cheap if you need
Old Aug 31, 2007 | 01:52 PM
Officially, the bottom half of the distributor doesn't come apart. So you are on your own finding bearings, seals, etc. for it.
Old Aug 31, 2007 | 03:45 PM
Koireland's Avatar
Oh alright, I found a kit from the UK with the shaft, bearing, seal, but for as much as that\s going to cost plus get put in, I think I'd rather get a new one. What kinda price are you talking Phillstubs?
