How to replace a distributor?
Old Aug 31, 2007 | 05:21 PM
PhilStubbs's Avatar
Default RE: How to replace a distributor?
i have seen them for less than $200us. here is one company http://www.xenocron.com/catalog/distributors-c-37.html
Old Sep 5, 2007 | 05:03 PM
Koireland's Avatar
When I turn the little fan looking thing to line up with the cap off how will I know when its lined up?
Old Sep 6, 2007 | 02:41 AM
PhilStubbs's Avatar
it will only go it one way, keep turning till it drops in. its pretty simple
Old Sep 6, 2007 | 06:40 AM
It's sometimes possible to engage the distributor 180 degrees off of the correct timing. If it won't start after you put it all back together, try pulling the distributor out and turning the rotor half a turn.
Old Sep 6, 2007 | 08:31 AM
PhilStubbs's Avatar
no. its impossible. the only way that could be is if the distributor housing is off. but if you put it on the same way the other one came off then your only other problem coul dbe plug wires on wrong
Old Sep 6, 2007 | 08:44 AM
JimBlake's Avatar
ORIGINAL: PhilStubbs
no. its impossible...
You'd be surprised what's possible.
I've heard of people forcing it in backwards. Just look at it- notice that the blade is offset from center. Same for the slot in the end of the camshaft. Line them up. If it doesn't slide in easily, DON'T get that hammer from your toolbox.
Old Sep 6, 2007 | 09:54 AM
Koireland's Avatar
Got her in with no problems, lined the new one up like the old one was in the 3 holes, think I need to take it to get timing adjusted?
Old Sep 6, 2007 | 10:07 AM
PhilStubbs's Avatar
i have tried to put it in backwards just to see and no matter what i did i couldnt make it go.
you should have the timing adjusted, but you arent going to hurt anything if you drive it. on a stock engine you can adjust it fmro one extreme to the other and it will be fine. it wont always run good, but it wont hurt anything
Old Jan 9, 2009 | 12:53 PM
suicidetuna's Avatar
So I guess you just need to mark the rotor position since the distributor can only go in one way...or do you even need to mark it?
honda_farmboy
Dec 20, 2007 11:43 AM
ELLAS1945
May 3, 2007 08:24 AM
baker7598
Jun 21, 2005 11:47 PM
ohbiskits
Dec 6, 2004 09:32 PM
mcbob
Nov 22, 2004 03:24 PM
