I can't believe I did this!
Old Jan 17, 2008 | 09:49 AM
cabofixe's Avatar
Default I can't believe I did this!
Alright... I feel like an idiot. I was installing indiglo gauges in my 97 Civic and I totally broke my fuel level gauge... ugh. Is there anyway to replace just the fuel level gauge without buying an entirely new console? Or is there an after market 2" gauge that would work? that I could just install into my 3 gauge pod? Thanks.
Old Jan 17, 2008 | 09:55 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: I can't believe I did this!
you could swap a fuel gauge from another cluster in... tried to remove the needle, haven't you? [:@]
Old Jan 17, 2008 | 10:51 AM
SevenKRedline's Avatar
Member
I did the exact same thing about 4 years ago. Went through a honda oem replacement part website (dont remember who) and switch out the entire cluster. I never tried it again since. I was pretty upset when this happened. I got the other two face plates on with no problem, but that fuel/water temp gauge is a douche!
Old Jan 17, 2008 | 11:06 AM
well is this a DX or EX with tach?
if its a DX cluster a used cluster should be cheap... but if a EX IF YOUR LUCKY youll find someone with a cluster iwth a busted speedo or tach...
BUT if its a EX/SI cluster with the temp/gas gauge on the right side than you cannt just replace just the one gauge... they are made together in that side panel, the cluster is made up of 3 panels... like pictured in my DIY led thread..
very easy to swap out those 3 sections at least....
ya should have done your research...
THESE NEEDS ON ANY HONDAS DONT COME OFF and they dont move much either before snaping
I WISH THEY DID..... than i could put on some sweet needles like clear or painted but they dont..
cloutston
Jul 20, 2006 02:58 PM
sellyoursol
Sep 4, 2005 05:29 PM
Auto98EX
Aug 9, 2005 03:08 PM
