i got 2 probs plz help
alrite first of all i got oil dripping from between the oil pan and the belt any ideas on what that could be...and the 2nd prob is i have smoke commin out of the exaust and im preddy shure its oil...plz help me out
Oily smoke that gets worse when you floor it usually means the piston rings are worn out. But do check that the PCV valve is not clogged up.
The oil leaking from the end where the belts are is probably the front crank oil seal. It's not too difficult to replace but kind of a waste of time if the engine is worn out anyway.
lol.... is this a stock motor? if it is, i would look into a new platform... like a b-series...
if you've already got a swap in there.... and mechanically inclined... rip it apart and replace the main seals alon with the pan gasket...... maybe some high compression pistons and forged rods too
To drive until summer or whenever you can afford to replace the engine, buy a case of oil and keep topping up as necessary.
I'd use 10W40 or even 20W50 (the "you need a new motor motor oil") as it is thicker and won't get used up quite as fast.
lol dont got cash rite now to drop a motor hopfully by summer but wat should i do till then
