i need help
Old Jun 7, 2011 | 05:16 AM
floresnj's Avatar
Default i need help
Okay so here's my problem when I start the car everything is fine until I press in the clutch. when I press it in just a little is feels like its going to die. so when I press the clutch in and try to put it on first it dies what can the problem be? Help please
Old Jun 7, 2011 | 07:45 PM
roque braceros's Avatar
I think when you press in the clutch you are putting some load on the engine
Old Jun 8, 2011 | 08:18 AM
droopy128's Avatar
Actually, you are releasing the load when press clutch down. Wat year is the car and does it idle ok?
Old Jun 9, 2011 | 04:56 AM
floresnj's Avatar
Its a 94 honda civic and yeah it idles at 800-1000 rpm.
Old Jun 9, 2011 | 05:02 AM
What you are saying makes little sense. It is extremely rare for a car to do what you say. For the engine to stall when you press the clutch down would take a very rare sort of major mechanical problem, which would also make a lot of noise.
How are you starting the car without pressing the clutch down? The starter should not work unless the clutch pedal is pressed to the floor.
While you have the transmission in neutral, does it matter if you press the clutch or not?
Old Jun 9, 2011 | 08:16 AM
techtalk's Avatar
^I concur entirely- this sounds like a very bizarre issue indeed. I was initially inclined to suggest that perhaps the OP's throw out bearing is kaput because that happened to me once in my old Civic. However, you DO need the clutch to start the car unless you hot-wire it. (outside of Crime Syndicate movies, does anyone even know how to do that? ) We definitely need more information before we can help diagnose the problem..
Old Jun 9, 2011 | 12:08 PM
PunisherInOKC's Avatar
^ very easily. look at clutch pedal where it attaches to the assembly. You should see a sensor with two wires. Pull the wires out and connect them to eachother. Solder and wrap.
Old Jun 10, 2011 | 06:35 AM
floresnj's Avatar
Yeah it happens when its in neutral. When I press the clutch in it starts to rub and I'm starting to believe its my pressure plate.
Old Jun 10, 2011 | 07:12 AM
So you hear a lot of noise? It's either the throwout bearing (which will tear up the pressure plate, might as well change the whole clutch set) or it could also be the thrust bearing in the engine. Have someone watch the crank pulley see if the crankshaft moves from end to end (side to side in the car) when the clutch is pressed. If the sheet metal cover on the bottom is almost touching the flywheel you could get noise from it when pressing the clutch pedal down, that could also be because the thrust bearing is bad and letting it touch.
Old Jun 10, 2011 | 07:34 PM
floresnj's Avatar
Yeah I hear like a squeak noise and then if I clutch all the way in and try to put it in first it just dies. So thank you for your help I'm going to see it. thanks
TunerShark
Sep 23, 2006 05:27 PM
rx9790
Nov 1, 2005 05:53 PM
Jas10hon
Jul 4, 2005 10:35 PM
CivicCrazy
Nov 29, 2004 11:50 AM
