I NEED HELP! CIVIC WON'T STAY ON
Old Oct 12, 2007 | 08:59 AM
04BLKCHEVY's Avatar
Default I NEED HELP! CIVIC WON'T STAY ON
Hello! My wife has a 2002 Civic LX with the 1.7l. The problem is that the car won't turn on unless i accelerate it. Once its on and i let go of the gas it turns back off. The car will stay on if i keep accelarating it. What could this be? This already happened once a couple months back and went away. Thanx
Old Oct 12, 2007 | 09:23 AM
Default RE: I NEED HELP! CIVIC WON'T STAY ON
I thin you're saying it will run if you keep pressing the gas but it won't idle. That probably means the idle air control valve is stuck closed. It's kind of an expensive part but you can try cleaning it first instead of replacing.
Old Oct 12, 2007 | 09:36 AM
04BLKCHEVY's Avatar
yea it will run if i keep pressing the gas. Where is the idle air control valve?
Old Oct 15, 2007 | 10:40 PM
Civic Si 00's Avatar
take off your Idle Controll Sensor (air valve)its located in the back ofyour intake manifold. there should be 2 bolts and 2 lines and a eletric plug . Were is pluged in it's a round cylinder black shape.
****Try to clean it 1st.. Go to any auto parts store and tell them you want a cleaner to clean your Idle control sensor air valve.*** Let me know????
pinstripe
Aug 10, 2014 09:11 AM
soxfan098
Feb 3, 2014 10:40 AM
Pyr0TeK
Mar 29, 2007 02:34 PM
jepasion
Jul 26, 2006 09:22 PM
visualpoet
Aug 1, 2005 02:22 AM
