IAC valve
Old Jul 6, 2007 | 04:25 PM
tamas's Avatar
Default IAC valve
Hi!!
I've been getting the same P0505 code. I already got the IAC valve replaced, couple of days later I got the same symptoms back.. Idle gets stuck on around1500 while in nutreal, while it's in firtst, or second gear it'd go up and down, like I was playing with the gas pedal. One day it'd do it, the next day it won't.
All vacuum hoses seem to be fine..
I ran out of ideas..
Tom
Old Jul 6, 2007 | 04:52 PM
Default RE: IAC valve
Check that the throttle plate and cable are not sticking. If the throttle is stuck open a little so the ECU can't get the idle down, it may throw the IAC code.
dmathews
Feb 7, 2010 10:17 AM
brinriha
Aug 14, 2007 06:33 AM
scamil87
Feb 6, 2006 09:24 PM
jlh911
Jun 30, 2005 09:52 PM
hypnotixcrx
Feb 27, 2005 10:56 PM
