idle problem
So i just installed a megan underdrive pulley and now my idle is slightly jumpy
it happens consistently and sometimes dips below 500 rpms even with no components running. The only thing i can think of is that since the idle control valve is run by voltage received from the ecu, is the underdrive pulley not getting the valve enough voltage to function correctly?
edit: could this also be the timing? as i changed the timing belt and water pump at the same time, so if my timing is off like 2 degrees could that be causing a weird idle?
Budd, I got the same problem. I didnt even change the pulley, I put a CAI in and I think thats part of the problem. The car isnt programmed to notice these types of upgrades and takes time to break in. I changed my gas to Ultimate and it seemed to stop. Then I changed to Premium and it was doing it again. So try changing to the best gasoline and see what happens. To be honest I thought my car was riding a lot smoother, so give that a try also
^Aren't you supposed to be running Premium in your Si?
at any rate, changing fuels isn't going to help.
bp4131017 - You've got to make sure that you lined everything up correctly when you put the new belt and pump in. Then from there set your idle, then set your ignition timing. If you've still got the idle issues, try bleeding/filling the coolant.
ORIGINAL: Forty04
92sicivic
Jun 21, 2012 03:35 PM
honvic
Sep 2, 2011 09:49 PM
JBaris
Nov 22, 2010 03:56 PM
redlines4us
Aug 22, 2006 05:49 AM
