idle surging
Old Feb 11, 2007 | 02:47 PM
patcheway's Avatar
Default idle surging
i have a 92 civic with a d16 the idle surges when you first crank it until it warms up i replaced the tps,iacv,only because the ecu was giving that code.after replacing those the ecu gives a new code one long flash then 4 short which in the chilton says crank angle positioning sensor.any ideas thank you
Old Feb 12, 2007 | 12:01 AM
fglaustin's Avatar
Default RE: idle surging
i would probably replace all the vacuum hoses - cost 2 to 3 dollars. i did that.
did not replace the 2 big ones - off of the brake booster or off the iacv (or eacv).
should be able to look at them at tell if they are bad - those small hoses though, you cannot do that - at least i could not.
mikecivex
Jun 9, 2007 05:20 AM
asolde
Feb 7, 2007 08:23 AM
bw1339
Jan 25, 2007 09:30 PM
barterj
Jan 25, 2007 02:39 PM
Devil
Jan 31, 2005 03:16 PM
