Ignition Timing for 04'
Can the ignition timing be advanced or retarded on a 7th gen civic? I have a 2004 that is making pre ignition like sounds. Since there is no distributer, how is the timing adjusted? I checked the plugs and they are fine and I'll put in a higher octane fuel on next fill up to see what happens. Any thoughts?
Yes, on a stock setup it is not adjustable. The crank sensor drives spark timing on the distributorless engines. Make sure the cam is in time though (timing belt could have skipped).
There could be excessive compression due to carbon in the cylinders; try the Seafoam treatment.
