Injector Plug question, answer needed asap
Old Jul 18, 2006 | 08:16 AM
Default Injector Plug question, answer needed asap
Alright guys, nearing the end of my turbo install, hoping to finish it up tonight. I was installing the new injectors last night, and when I went to plug the little guy pictured below back in, it didnt fit. Am I trying to connect it to the wrong piece, or am I just not seeing the trick?? Heres a couple pics..
[IMG]local://upfiles/2331/9B1758DD80334FE194CA6CC42A5CE53E.jpg[/IMG]
[IMG]local://upfiles/2331/94D6CF10DD5B4D94B96C736A29D2F32C.jpg[/IMG]
[IMG]local://upfiles/2331/6A512B473F174E829F5644A0CBBCC6C2.jpg[/IMG]
...and heres a dirty little teaser
[IMG]local://upfiles/2331/471B95A6EA964D64863A2EC159FE9BB5.jpg[/IMG]
Keep in mind we had to "engineer" a few things, so its not very clean right now. But once its running, and tuned, I can spend the following couple weeks cleaning everything up
Old Jul 18, 2006 | 08:25 AM
Chimera02EX's Avatar
Default RE: Injector Plug question, answer needed asap
See attached picture.
[IMG]local://upfiles/4662/97470F779E6A4D699889BC4635D717FE.jpg[/IMG]
Old Jul 18, 2006 | 08:38 AM
Well, I did try it the other way too, but it doesn't seem to want to fit that way either
I do have the right plug don't I?! It's the clip wired into the Injectors
Old Jul 18, 2006 | 10:46 AM
hmm I'm not sure then 40....
Old Jul 19, 2006 | 07:30 AM
I found out it's an OBDII sensor, which I no longer need. Thanks for your help Chim
Old Jul 20, 2006 | 08:47 AM
Well, everything is fixed now. The reason it didnt fit (long story short) is because the plug I'm holding is the stock injector clip. My buddy got a lil confused when wiring my injectors
Old Jul 22, 2006 | 12:33 AM
POLYTHING's Avatar
nice 40! you gotta show me how to install the turbo when I save enough $ okey?
Old Jul 24, 2006 | 08:09 AM
Will do man. Also, a word of advice, make sure you have an extra $200 or so on hand when it comes time to install. You're going to need it for all the random crap you'll need along the way
scruffy1331
Apr 7, 2010 12:37 PM
colby_666
Mar 28, 2010 03:33 PM
didder
Feb 9, 2008 01:00 PM
drbyers
May 3, 2007 12:13 AM
classiccarsrule85
Dec 1, 2006 11:05 AM
